Rh7 sp10
test-R.3dm (1.6 MB)
Hello - use the Sweep2 output here with some ‘Add Slash’
Hello, why is this option not showing up output curve segments R7-SP11
Hi - Please run the Rhino SystemInfo command and copy-paste the result here. Also, in your Windows System settings, what do you have the screen scaling set to? -wim
SystemInfo
System
Thanks for replying the problem was because of the advanced scaling settings option was 110% It works normally if the option is 100%
