I need to draw on an existing JPEG file. But I can not…
To import my image I type: image (surface / plan / image) then I insert my jpeg image on my workspace by adjusting the scale.
But sometimes the image is no longer visible, only a white square is visible (the surface object). It is impossible to see the JPEG drawing.
Has anyone ever encountered this problem.
Is there another more stable way to import to a jpeg image?
A white image display on a PictureFrame (V5), or Picture (V6) is an indication of the display driver problem.
If you’re in V6, open the Notifications Panel.
Is there a warning about an old display driver?
You will probably need to visit the Web sites for your graphics card makers to get updated drivers. The automatic check for update tools have a near 100% failure rate.
All currently supported display adapters should have drivers less than 2 months old.
