Problem going back from Bongo3 to Bongo2
Hi, i tried Bongo3 but want to go back to Bongo2.
Various attempts to uninstall didnt work for me. Bongo2 wont install any more, even after i completely uninstalled and reinstalled Rhino. Also deleting the Rhino folders in C:/programs didnt help?
Any ideas?
In Bongo’s Program Files folder there is BongoVersionSwitch.exe. Executing this as administrator allows you to switch in between versions.
Luc
Hi @Luc and thanks for your reply! I marked it as solved, but realised now its still giving errors… I switched back to Bongo 2 and it throws me “unkown command” in the command line, once i selected bongo functions?
I think the easiest would be a clean install, how do i do that?
P.S. another error that i have is that the bongo tab is missing in the rhino object properties window?
I sounds like Bongo in no longer installed, hence “unknown command” and the missing tab. I think you should delete all versions of Bongo (insofar as there is still something present) via ‘Apps’ in Windows Setting.
Then run Bongo’s installer Bongo_20_Release_x64_English_20190212_2_6_26922.msi
Luc
thanks, uninstalling and reinstalling both worked, plus i had to reactivate Bongo2 in the Pluginmanager. All back to normal now!
