Problem exporting to PDF
Having a problem whenever I export my file to PDF. I export as a Vector file and it’s always been fine, but recently when I do so and try and open the PDF on my desktop through Adobe Acrobat it comes up with this message: “there was an error processing a page. There was a problem reading this document (110).”
I’ve tried removing text and images but that doesn’t seem to be the issue as it exports fine.
I’ve removed detail views from layout and this is where it stops exporting properly but I can’t work out why as some detail views export fine.
Any help on this would be much appreciated as I’ve spent hours trying to work it out at work.
Thanks
Hi David -
I don’t think I’ve run into this one before. Could you post a (simplified?) 3dm file that behaves like that so that we can check that further here?
I recently had the same issue printig with RhinoPDF, since transparancy isn’t printed clean with AdobePDF Printer. It was caused by a gradient-hatch i used.
Sadly, there was no problem after i removed the gradient.
