Hello everyone,
I’m sure it’s something trivial but i can’t figure out what i’m doing wrong, it’s been hours and i’m desperate…
When i use the Export component from Elefront it does create all the correct files in the right folder but in each file i puts all the geometri and not the single element it should… Even with a short list of four elements…
Thank you
@Daniele1 You just need to graft the trees going in to the “Name” and “ID” inputs. For every file name you provide, the component will work on a list of objects. So by providing a flat list into the ID component, each file exported will contain all objects in that list.
I also noticed you are using a button component to activate the Export component. I believe this button is a custom button, but the component is not reliable with a button to activate it. This is because in Rhino6 and earlier, the Export component has to use the command line execute the commands, effectively leaving GH to do the work.
Pancake’s Export As, as well as Elefront’s Export component, enables exporting multiple geometry into one file. So that each datatree branch represents one file.
Without grafting, you would only have one datatree branch. Grafting puts each object into its own datatree branch.
Is the geometry in the active document, or is the geometry “Grasshopper Only”? In this version of eleFront and R6, the geometry must be in the active document to be exported.
@Daniele1 here is the script for you to review. In this script I generate some boxes, bake them, then reference, and export. Should contain all the key, basic elements. export.gh (14.9 KB)
