Could we have it expanded with custom width? I don’t even know how to find & edit the standard lines.
Used to be easy in V5.
Or add it to the options like linetypes and hatches.
What a lot of people don’t realize is that the print width box is not only a dropdown, you can also type in a custom value. So you can select your curves, then highlight the current value and just type in a new value (whatever you want). Unfortunately, this value is not added to the “standard” list, that list appears to be hard coded Edit: it is possible to edit this list, see post #5 below
Here’s a quickie script that allows you to set the print width of pre- or post- selected objects via the command line:
"""Sets one or more object's print width. 0==Default, <0==NoPrint"""
import scriptcontext as sc
objs=rs.GetObjects("Select objects to apply print width",preselect=True)
if objs:
if "CustomObjPW" in sc.sticky: prev_width=sc.sticky["CustomObjPW"]
else: prev_width = 0
pw=rs.GetReal("Print width?",prev_width)
if pw is not None:
rs.EnableRedraw(False)
for obj in objs:
rs.ObjectPrintWidthSource(obj,1)
rs.ObjectPrintWidth(obj,pw)
sc.sticky["CustomObjPW"] = pw
OMG! So obvious yet hidden feature. It is really hard to guess it’s there.
Did anyone (except you and McNeel folks) knew about it?
Can I have a py (preferred) or rvb, please?
Sure…
SetObjectPrintWidth.py (569 Bytes)
I actually looked in the Help and it is mentioned.
It also tells us how to modify the standard list of line widths… that one I just learned… !
Wonderful! Thanks Mitch.
PS Long time users don’t read help anymore
Too bad this folder and file don’t seem to exist in the Mac rhino… killing me
This is on the list as RH-75086 Files Not Available on the Rhino for Mac: colors.txt & printwidths.txt
