Thank you !
Please forgive my bad english !
I made an architectural project and I created layout .
The problem is that I don’t know how to save those layout in PDF in order to send them to the printing company.
Thank you for your help
Hi Christian,
You will need to install a (free) pdf printer and go through the regular print dialog where you select the pdf printer. Note that windows 10 has a buildin pdf printer.
https://wiki.mcneel.com/rhino/creatingpdfs
Does this help?
-Willem
Thank you
Is it normal that when a use the pdf printer in Window 10 or even another pdf creator that I have download the format save is '‘prn’'
thank again
Hi Christian,
No, you can only print PDF files not PRN. Do you need PDF or PRN?
Make sure -NOT- to check “Print To File”
Thank you !!!
have a good evening !
