Printing a picture object
I’m having the same problem on a Apple M1 silicon Mac running Rhino 7.
Neither the lineweight nor locked objects solutions work for me.
Any ideas?
I’ve tried reimporting the image as both a material and as picture.
Thanks,
Jack
Hi Jack -
I’ve moved your post to a new thread - an issue reported almost 7 years ago might look similar but in the meanwhile, the Rhino version, the OS, and the hardware has drastically changed.
Could you post a small sample file and explain how you are trying to print the file?
Hi Wim,
Thanks!
I have attached the file. I am trying to print layout page 1 using the normal system dialog (command p). I’m running 7.12.
Thanks,
Jack
Picture Frame.3dm (7.3 MB)
this doesn’t print to pdf correctly on my windows machine either :man_shrugging:
On my Intel Mac, it doesn’t print either.
Hi Jack -
On macOS, the recommended way to create a PDF file from your Rhino file is to use ExportAll and pick the PDF format. This will use the RhinoPDF printer that we can debug and improve.
As for the not printing of the picture, I finally figured out that this is caused by the object that is using the Glass material on the “Acrylic” layer. If you turn off that layer, the picture will print to PDF. Alternatively, you could use the Raster output option instead of vector but that might not be desired.
I’ll get the issue with the glass on the list. - RH-66144
Thanks,
