No big deal for now, but just wanted to mention that PrintDisplay
scaling seems to be off in Rhino 8 compared to RH7. Below a file opened in RH7 on the right and RH8 on the left:
PrintDisplay has been modified to display curves in world thickness. If you have a 1mm thick print width, the curve will display as 1mm thick in world units. You can adjust a scale in the PrintDisplay if you want to change this.
This feature now allows curves to increase/decrease in thickness as you zoom in and out.
Oh ok thanks, forgot to check that!
