PrintDisplay and 'No Print' print width not working in Rhino 6
Draw a line, set its print width to ‘No Print’, toggle on PrintDisplay.
The line disappears for me in Rh5, shows normally in Rh6.
Can you reproduce this?
Hi Duncan - I can’t reproduce that here in RH6 for Windows.
Can you please run the Rhino SystemInfo command and post the result here?
Rhino 6 SR16 2019-7-9 (Rhino 6, 6.16.19190.07001, Git hash:master @ a8b4ee102e9e0eb1d11825df063e13f96d518f93)
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 7-24-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.70
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-24-2019
Driver Version: 26.21.14.3170
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
Thanks for that, Duncan. That looks fine - but you left the plug-in information out.
Is it behaving differently when you start Rhino in safe mode?
I cannot reproduce the error in safe mode in fact! Works fine there.
Rhino plugins
…\Commands.rhp “Commands” 6.16.19190.7001
…\rdk.rhp “Renderer Development Kit”
…\RPC.rhp “RPC”
…\AnimationTools.rhp “AnimationTools”
…\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\CreateQuadMesh (5bf6c0f3-3657-4ad5-834a-bbbb52706a40)\6.0.6950.16446\CreateQuadMesh.rhp “CreateQuadMesh” 6.0.6950.16446
…\RhinoRender.rhp “Rhino Render”
…\rdk_etoui.rhp “RDK_EtoUI” 6.16.19190.7001
…\rdk_ui.rhp “Renderer Development Kit UI”
…\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
…\NamedSnapshots.rhp “Snapshots”
…\RhinoCycles.rhp “RhinoCycles” 6.16.19190.7001
…\Toolbars\Toolbars.rhp “Toolbars” 6.16.19190.7001
…\3dxrhino.rhp “3Dconnexion 3D Mouse”
…\Program Files\Next Limit\Maxwell for Rhino\maxwell_rhino.rhp “Maxwell for Rhino” 4.2.6.2
…\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
…\BlockEdit.rhp “BlockEdit” 6.16.19190.7001
…\Displacement.rhp “Displacement”
…\NamedPositions.rhp “Named Position”
Thanks.
Could you try again in normal mode but with Maxwell and V-Ray disabled?
Hi Wim,
it is in fact V-Ray. Once the plugin is disabled, PrintDisplay works correctly.
I also just updated to V-Ray for Rhino v4.xxxx but the problem persists.
Is this a fix on V-Ray’s or Rhino’s side?
Hi Duncan - Thanks for that information!
This is something that would need to be fixed by Chaos Group.
CC: @Nikolay
Thanks.
The problem is identical for both Rh5 and 6 btw. Hope this can be addressed.
