Printcolor turns pale when set to technical view
Hi
I have noticed that print color tuns pale after setting the diplaymode of a detail view to for instance “technical” .
I have tried isolating the annotation with _SetObjectDisplayMode to wireframe but does not seem to help.
Any ideas?
printcolor turns pale.3dm (63.2 KB)
Hi Vincent -
Thanks, I’ve put this on the list as RH-80017 Display: Washed out colors
Hi Vincent -
Apparently, this behavior is currently defined by the gamma setting for rendering. The plan is to expose this setting for technical display modes, but, for the time being, you can change this by turning off “gamma” in the Rendering panel:
This will also affect rendered display modes and you might need to toggle this as required.
Hi Wim,
Bedankt, that is working for now!
