I am trying to use Print(msg) within a class in c# component and got this message - Error (CS0038): Cannot access a non-static member of outer type ‘Script_Instance’ via nested type ‘Script_Instance.Island’ (line 206). Any idea?
Where do you want to print? To out param or to Rhino command window? I’m guessing that the second is the case and you should use one of those Rhino.RhinoApp.WriteLine()
Don’t know for what you need it but if you want to use it often then pass it in constructor and make backing field in class - it will be easier to use it. Otherwise if in one method only just make place for object of script in method call params.
