What I’m trying to do is to match up Print Width in Rhino to Adobe illustrator point unit. How do I achieve this? In the end, I’d like to produce all drawings in Rhino without further steps. (I usually export Rhino file to .ai and do in illustrator) There is only mm unit in Rhino for Print width…
The international standard for line widths in technical drawings (ISO 128-20) list default lines in mm. I guess that’s why nobody thought of implementing line weights in pt.
You could define your own set of default lines widths with
1 pt = 0,35278 mm
But you probably know that.
Other than that, I’m not even sure, line widths are kept consistent from Rhino to AI.
