Print: separate DPI settings for vector and raster output
Hi team,
Would it be possible to add two separate resolution options in the Print dialog, one for vector output and one for raster output?
In architecture, plans need a really high DPI (2400 or 1200) to keep line weights, hatches and small details crisp. But rendered images and textures don’t need anywhere near that, 300 dpi is plenty. Right now there’s only one value for the whole job, so if I set 2400 for the plans, the images get rasterized at 2400 too and the files become huge and slow. If I lower it for the images, the linework suffers.
Having something like “Vector output: 2400 dpi / Raster output: 300 dpi” would solve it and save a lot of back and forth.
Thx!!
Hi Feñus -
I could be confused, but the DPI setting does not affect vector output. Are you seeing something else?
The other day I printed a architecture plan and while Rhino let you choose any lineweight you want 0.07, 0.11 for example, not the standard, I analize through Claude the output pdf and Rhino choose the lineweight based on the dpi and if any dpi didn’t fit with the the amount of points it would choose the closest that it has. So I went to AutoCAD and I figured it out that one of the presets has High Quality Print has 2400 dpi for vector linework and about 300 or 600 dpi for raster images and I thought it would be great to have that separate but maybe I’m concercing through something very specific btw.
Hi @Feñus
What view mode do have your detail/s in your layout page set to?
I think wireframe view mode is the only way to print in vector or you have to use make 2d and then show that in a detail. Lines, curves, hatches and wireframe view mode are I think the only items that Rhino prints to vector.
If you have your layout detail set to technical or any other shaded view mode that will be printed as raster.
Maybe your digging deeper than I understand but I always thought that vector printing uses mathematical paths instead of pixels, so they scale cleanly at any size, thus their small file size compared to an equal looking print saved in raster.
RM
Hi Feñus -
fwiw, you don’t need to burn tokens to get Claude to guess what Rhino is doing. You can simply round-trip the PDF file back into Rhino to check line weights.
Apart from that, if you think something is wrong, please provide a sample 3dm file and the output from the Rhino SystemInfo command.
Roland,
For technical display modes, Rhino 7 is the last version in which that was the case.
