Print preview thickens lines but not points
V5
How can I get the points on a certain layer to stand out more ?
Steve
Point size is a display attribute. You can’t make they bigger by layer. You can change some things using the SetObjectDisplayMode command, but it doesn’t seem to work on points and control points. I think this is a bug.
I have great difficulty seeing them amidst my thicker lines I am creating , deliberately thicker as I need to have some items more visible.
real nuisance the points are blotted out.
Bug needs fixing, can this be given a fix code ?
Steve
http://mcneel.myjetbrains.com/youtrack/issue/RH-28014
There ya go.
:slight_smile: :slight_smile:
Ta
many will be happy to see points bigger as an option.
Steve
