Print Out Issue
I am not sure whether this is a but or not. When I print out in model space, every object below the level are shown like wireframe display mode. When I do that in layout, there is not problem. As far as I remember, I didn’t experience this issue in previous VA version. ( I use 2.11.3). Is this supposed to work this way for 2.11.3? If it is, it’s very uncomfortable, because users often need to print out in model space
Thanks
Hi @archist97,
Yes, this is a known bug that I discovered the last week. But this is just a bug in the Print Preview dialog. If you proceed and print, the resulting PDF will be just fine.
This issue has been already solved.
Thanks,
Enric
Hi
This is not preview issue. It is is printed out as shown in preview.
Thanks.
Hi @archist97,
OK, I’ve been able to reproduce the issue. If you print to PDF using the “Rhino PDF” printer that comes integrated with Rhino, the PDF output will be fine.
I’m going to include this fix in VisulARQ 2.11.4.
Thanks,
Enric
