Print of what is done in grasshopper
Is there any way to print or move to another program everything we do in grashhopper ?. If there is any way I would greatly appreciate your cooperation and thanks in advance.
You could use that Export Hi-Res Image…
and then print the image generated
Are you asking for a Grasshopper \rightarrow standalone code converter?
What I want to do is print everything I have done in grasshopper on a sheet different from the A4, because in A4 it is not displayed very well; Will there be any program that exports to Autocad or another program that allows printing, or in any case in the same program can be printed?
There is no Print in Grasshopper, just the high resolution export feature @laurent_delrieu mentioned. Once you have your images, you can print them on whatever paper format your printer supports.
