I am new to Rhino development in C#.
I was wondering if there is a way to print/display the name of a selected block on rhino.
I am just looking for a way to identify specific information regarding a selected block.
Thank you!
Thank you!
Hi @runningteens,
Try using this as part of a plug-in command:
var filter = Rhino.DocObjects.ObjectType.InstanceReference;
var rc = Rhino.Input.RhinoGet.GetOneObject("Select block instance", false, filter, out var objref);
if (rc == Rhino.Commands.Result.Success && null != objref)
if (objref.Object() is InstanceObject iref)
var idef = iref.InstanceDefinition;
if (null != idef)
Rhino.RhinoApp.WriteLine(idef.Name);
return Result.Success;
– Dale
