_-Print macro and print manually from GUI produce different size file?
I am trying to automate printing to pdf, because I have many sequential layers to print. I print from a A4 layout, in raster ; when I try to print in vector things that are in hatches do not appear properly. But this is not the issue. I noticed that when I print manually via the GUI (right click on layout - print - toggle selections and Print) the result file is about 900kb. When I use the command from the script (_-print *_*setup *_*viewport=“named viewport” *_*destination=“rhino pdf” etc) the resulting file is over 2000kb. I cannot find what would be the issue. The files look the same so the selections work, but something in the macro codes a lot more data in the final pdf. Why is this and how can I automate exactly the same procedure that happens when I right-click Print on a layout?
Is there a sample model we can run with?
