The appearance of Lines in Rhino 8 is perfect. The following would make the experience even better:
PrintDisplay Scale always resets itself when reopening a file. Could that be saved for the file?
Is there an option to set the PrintDisplay Scale for one file. We mainly use drawings with a single layout scale (only sometimes we have various scales). So we could specify the “scale” of the drawing which would be used by PrintDisplay-Scale.
That would require a change to the 3dm file format, so that would be something for a future version of Rhino.
I’m not completely understanding the request. I take it you are talking about the width of curves, not scaling the lengths of segments of different linetypes?
Also, you mention layouts - there is no scaling option in PrintDisplay for layouts.
Have you looked into using real units as width in the new-in-Rhino 8 linetypes? Using those, you shouldn’t need to have to worry about PrintDisplay anymore.
