Print bug: picture dimension values not updated
Hi…,
when I change in the current Rhino 8 WIP print dimensions and set the print window, the dimension values are set back in the input fields.
This is confusing/buggy.
Thanks
Michael
www.flexiCAD.com
Hi Michael, I see this works the same in V7. After setting the resolution, if you close the print window, then reopen and use the Window > Set…, does it stick? Here it does.
Hi Gijs,
yes, reopening the window helps.
Thanks
Michael
