Prinicipal Moment lines
I have a quick question regarding the principal moment lines component. The visualization of the m1 and m2 lines works without any issues, but I would also like to display the signs and magnitudes of the moments along these lines. Essentially, I would like to create different color gradients for the principal moment lines, distinguishing between m1 and m2 as well as between positive and negative moments.
Is there a way to generate this quickly?
What’s your hurry?
I’m not necessarily in a hurry; I’m just happy if I can get my problem solved. So if you have a solution, I would be very grateful.
Hello @FLML,
you could try to feed the principal moment lines into the “Section-Forces”-component (see here) and display Mnn and Mtt (Mtn should be zero or very small).
– Clemens
Hi Clemens,
thank you so much for your help — it was such a simple solution, and I just didn’t think of it. Now I just need to adjust the colors of the lines, but I’m confident I can manage that.
Thanks again!
