Hi @DavidRutten,
Not sure if it’s just me (I’ve tinkered with the Grasshopper XML files), but since moving to Rhino 6 I’ve noticed that the Preview Point Flavour
and Plane Size
values will reset when I close and open Rhino (also the Grasshopper window position/size appears to change, can’t quite remember if that’s “normal”):
Also, the Dot
point size seems a lot larger on my system than it was in Rhino 5. Perhaps there is a size setting somewhere, similar to how we can set the size of the planes?
Edit: I’m experiencing the same behaviour with Draw Icons
and Draw Fancy Wires
Best,
Anders
Sorry for the bump, but could someone confirm/disaffirm this behaviour?
I just went through a pretty intense design competition sprint, where especially Draw Fancy Wires
resetting to off every time I opened a new Rhino/GH instance led to some mistakes into the wee hours
I’m not seeing this on Rhino 6. Whatever I set seems to stay.
Ah fudge, then it probably is related to my customisations. Think I just copied/pasted the relevant Grasshopper .xml files when I updating from Rhino 5 to 6. Will try to delete those and make the .xml edits from scratch again.
Those point dots are still pretty damn yuuuuge though
Yea dots are dramatically bigger in display in R6 than R5.
