I’m trying to create a series of connected columns using the pipe component according to points order that has been generated using the divide curve component. In the attached files, in the first option, you can find that the order of the points is correct thus creating continuous columns for the defined mass.
However, In the second option, at a specific level, the order of the points is reversed and the starting point “0” is shifted by one index as described in the images.
Any hint on how to solve this problem? and what might be causing the sudden disorder of the points?
Thank you in advance.
Columns-Points-Order.3dm (172.2 KB)
Columns-Points-Order.gh (25.0 KB)
