Pressure residuals stalling at 10−2, I've tried up to 4000 iterations
Hi I want to do an urban wind study with tall buildings and I am currently using 3 boxes in rhino to run my analysis but it simply wont converge. I’ll detail my mesh settings and my check mesh log. Also my geometry settings and other values that might be causing this problem. I have tried different configurations of parameters but I always end up with the same results.
This are my general geometry settings all 4 buildings are similar, just boxes, but the the tallest is 100 meters tall:
Geometry:
Geometry consists of a valid extrusion defined as an extrusion surface with a closed U direction ranging from 0.00 to 121.12 and a V direction ranging from 0.00 to 100.00, following a path from coordinates (28.76, 31.23, 104.59) to (28.76, 31.23, 0.00), with both start and end capped and square miters applied at each end; the profile curve is a closed polyline composed of four points, beginning at (0.00, 0.00, 0.00), extending through intermediate vertices including (38.81, 0.00, 0.00), and returning to (0.00, 0.00, 0.00), with a domain from 0.00 to 121.12, and includes Geometry UserData identified by ID 2544A64E-220D-4d65-B8D4-611BB57B46C7 from the Rhino plug-in, described as RhinoCommon UserDictionary, not saved in file, with a copy count of 1.
The extrusion is always converted to a mesh inside grasshopper, before going as buildings inside the box domain. I’ve tried also to input meshes directly made in rhino without the need to convert them but the results are the same.
I’ve let eddy manually defined my domain dimensions and I’ve also input them manually: up to 1000 meters in lenght, width and height.
I’ve also mess around with my mesh settings to refine the definition of the mesh.
r/CFD - OpenFOAM/Eddy3D Pressure residuals stalling at 10−2, I've tried up to 4000 iterations - checkMesh reports thousands of  concave cells|750xauto
I’ve changed this values and mesh modes. I don’t have a terrain geometry connected into the box domain.
I’ve also change the relaxation value to 2 of the different options It let me: robust and optmize, being optimize the recommended by eddy and the one I’ve tried the most, the other options are fast and fluent style which I have not try. I am really a beginner in CFD so I don’t know much about this.
This is my mesh check which always gives me 1 failed check about concave cells, varying in number depending of what i try but I always get more than one thousand:
Checking geometry… Overall domain bounding box (-552.258 -613.409 -8.8817842e-16) (922.453 862.65 627.56365) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-4.5366769e-15 1.8142088e-15 2.9212416e-14) OK. Max cell openness = 3.3004302e-16 OK. Max aspect ratio = 12.149424 OK. Minimum face area = 0.18221313. Maximum face area = 257.9154. Face area magnitudes OK. Min volume = 0.10062993. Max volume = 3775.6381. Total volume = 7.3189627e+08. Cell volumes OK. Mesh non-orthogonality Max: 64.43236 average: 5.5692407 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.7183161 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.099843588 16.894994 OK. *There are 413 faces with concave angles between consecutive edges. Max concave angle = 74.418401 degrees. <<Writing 413 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.71850262 average = 0.99998683 *There are 8 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.71850262 <<Writing 8 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 0.015108128 average: 8.5555586 Cell determinant check OK. ***Concave cells (using face planes) found, number of cells: 7960 <<Writing 7960 concave cells to set concaveCells Face interpolation weight : minimum: 0.063949331 average: 0.48187802 Face interpolation weight check OK. Face volume ratio : minimum: 0.02206134 average: 0.92253269 Face volume ratio check OK. Failed 1 mesh checks. End
I’ve opened this concave cells in Paramview and are big blob of clusters surrounding the building in every direction, also the mesh of the buidlings is jagged on the corners when I load the geometry from the .foam file. The concave cells also appear in the center and end of the wind tunnel but in different smaller rectangular configurations.
this is my box domain which is currently 1000x 1000 and the height is decided by eddy.
r/CFD - OpenFOAM/Eddy3D Pressure residuals stalling at 10−2, I've tried up to 4000 iterations - checkMesh reports thousands of  concave cells|682xauto
This are my buildings neither of them really touch each it other. I am using Eddy 6.2.821 in Rhino 8. Hope some one can help me I don’t really now what I am doing wrong
WindPressureTigerLi.gh (73.0 KB)
R 0 Abmax.3dm (403.4 KB)
I’ll leave my files here in case someone can test it. Thanks
