Hi guys,
I found weird behavior in the preselection, here is my codes:
CRhinoGetObject sel_UnfoldObj;
//context.m_doc.UnselectAll();
sel_UnfoldObj.EnablePreSelect(); //TRUE, TRUE);
sel_UnfoldObj.EnableSubObjectSelect(true);
sel_UnfoldObj.SetCommandPrompt( L"Select the sheet metal model: " );
sel_UnfoldObj.SetGeometryFilter( CRhinoGetObject::surface_object); // for the time being, don't use this | CRhinoObject::mesh_object );
sel_UnfoldObj.GetObjects( 0, 0 );
int dx = sel_UnfoldObj.ObjectCount();
CRhinoCommand::result re = sel_UnfoldObj.CommandResult();
if( sel_UnfoldObj.CommandResult() != CRhinoCommand::success )
return sel_UnfoldObj.CommandResult();
Now before I issue the command in the command line “mycommand”, I have already select many one or many objects, then I issue “mycommand”, it ends up with asking for selecting the model (command prompt to ask me to select), then I hit return, the selected object is “dx = 0” and the returned status is “canel” (value 1).
Where are my preselected objects?
Is anything wrong with my codes?
Thanks for help.
Regards
Eric
