Precision Stretching in Perspective View
I’ve never developed an simple method for stretching an object to a given dimension without leaving a 3d view or subtracting in my head as I work.
How do I make a box that’s 5’ x 2’ x 8’ into one that’s 6’-3" x 3’-2" x 12’-4" by inputting the target dimensions?
I’ve got a few ways of doing this but my usual way is to either draw temporary reference objects (in this case probably a rectangle) or copy faces the distance(s) you want. I usually do the math and check it after.
I experimented a bit just to see if there’s an alternative (better for some for sure - I’m mostly stuck in my ways though), but if you hate dealing with temporary objects you could try “Scale1D”, and if you like that try “ScaleNU”. Scale 1D will have you pick the object, the basepoint, and then you can select a reference, and then you type the distance.
ScaleNU does all 3. It seems to be throwing me off because when I type the distance, I can’t hit “enter” to confirm, but rather I actually have to click on the screen. It works a little funny (from my perspective) but does all 3 directions.
Perhaps BoxEdit?
Thanks for the thoughts. I see that project has to be turned off in the snap settings and then it works as expected.
