Precision Issues with Feet and Inches in Rhino and Grasshopper
I’m encountering a precision issue when using Rhino and Grasshopper to perform unit conversions and calculations involving feet and inches.
The Problem:
When converting inches to decimal feet and then performing operations, I’m not getting the expected precision in results. Specifically:
  • Example Calculation:
    • Starting with: 0.083333333333333 (should represent 1 inch as a decimal of a foot)
    • Operation: Multiply by 2 (should result in 0.166666666666667)
    • Operation: Multiply back by 12 to convert to inches (should result in exactly 2 inches)
Instead, I’m getting a result close to 1.999992 rather than exactly 2, indicating a loss of precision.
What I’ve Tried:
  1. Adjusting Rhino’s Document Settings:
  • Went to File > Properties > Units
  • Increased Number of Decimal Places to 15 or more.
  1. Using Grasshopper:
  • Used Expression components for precise calculation steps: x / 12, x * 2, and x * 12.
  • Configured Panel components to display more decimal places for verification.
Despite these adjustments, the precision issue persists.
My Setup:
  • Software Versions:
    • Rhino: [Specify version, e.g., Rhino 7]
    • Grasshopper:
Request:
Has anyone else experienced similar issues with precision in Rhino and Grasshopper? If so, how did you resolve them? Are there any additional settings or best practices I might be overlooking?
Thank you for your assistance!
Unit Precision Issues with Feet and Inches.gh (12.8 KB)
It’s not a Rhino or Grasshopper thing, it’s that computers are REALLY bad at fractions:
Cheers
DK, from the modern world, where we use mm and live much happier lives, but still have problems with decimals in binary…
Hi
thanks for sharing the video
well explained
Why i m getting different results in the same thing
You are not doing the same thing in the two definitions. In the first one you are using data that has passed through a panel. There text conversion happens with rounding.
You should never pipe data through a panel and use the panel output. You are not guaranteed to be working with correct data.
In short: Do Not Pipe Data Through Panel.
thanks
