Just exploring if panning is scriptable in Rhino 5.0, as there are no commands for precise panning. It would be very useful for arranging drawings in detail views for layout.
For example I would like to pan within a detail view 400 units in the x direction.
Any ideas how this would be possible?
Something like this:?
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
Dim x As Integer
Dim y As Integer
Dim z As Integer
RhinoGet.GetInteger("Move X (As integer)", True, x)
RhinoGet.GetInteger("Move Y (As integer)", True, y)
RhinoGet.GetInteger("Move Z (As integer)", True, z)
Dim view As Display.RhinoViewport = doc.Views.ActiveView.ActiveViewport
Dim target As Point3d = view.CameraTarget
target.X = target.X + x
target.Y = target.Y + y
target.Z = target.Z + z
view.SetCameraTarget(target, True)
doc.Views.ActiveView.Redraw()
Return Result.Success
End Function
Right mouseclick on the rhp file and unlock.
Then drag and drop in rhino and use the command Pan2
or script it like: Pan2 Enter 10 Enter
it pans Y + 10
pan2.rhp (12 KB)
Great! It works well on my end. Thank you for writing that.
Would it be possible to integrate a pan from… to… element to that command? Does this psudeo code make sense?
get “pan from” co-ordinates = F
get “pan to” co-ordinates = T
T-F = A
camera target co-ordinates + A = new target co-ordinates
Pan2.rhp (13.5 KB)
Commands:
Pan2 - With X, Y, Z settings
PanFromTo - will set 2 points for distance and will save the “jump”
PanRedo - Redo the same “Jump”
PanFromTo
Dim PtFrom As Point3d, PtTo As Point3d
RhinoGet.GetPoint("From (Pick Point)", True, PtFrom)
RhinoGet.GetPoint("To (Pick Point)", True, PtTo)
Dim PtNew As Point3d = PtTo - PtFrom
view.SetCameraTarget(PtNew + target, True)
My.Settings.X = PtNew.X
My.Settings.Y = PtNew.Y
My.Settings.Z = PtNew.Z
My.Settings.Save()
End Function
PanRedo
Dim pt3D As New Geometry.Point3d(My.Settings.X, My.Settings.Y, My.Settings.Z)
view.SetCameraTarget(pt3D + target, True)
End Function
Thank you for publishing the code again, very useful for me learning.
One minor thing. When using the PanFromTo command, I feel it does the reverse of what is requested, ie. it pans from the second point to the first point? Pherhaps I’m misunderstanding the steps, but it feels counter intuitive.
Anyway thanks again, very useful!
B
Just tested it and it pans from the first point to the second point.
No problem.
Jordy
