Is there anyway to get a variety of windows, doors, walls, etc (other than the default setting) pre-built or do I have to create all these elements myself?
You can import the library (VAL) using these methods:
For instance on my computer there are VAL files here: C:\Program Files\AsuniCAD\VisualARQ 2\RHINO5x64\English\Libraries\Imperial
You can also start a document using one of the provided templates. You can find them inside the “VisualARQ 2” folder when you run the New command.
And you can also create your own .3DM templates, using the SaveAsTemplate command) and .VAL libraries (using the vaStylesExport command).
Enric
