Using a _Copy to copy of block instance does not copy the UserData (specifically UserStrings), whereas Copy/Paste does copy the UserData. Should _Copy copy the UserData?
Thanks
Paul
Thanks
Paul
I’m not able to repeat this. If I create a block in Rhino and run the SetUserText command on that block, the user string gets copied around with the instances
You are right Steve, it was a fault in my code. It was due to handing the Rhino.PlugIns.ReadDocument event for Paste events (but this is no firing for the _Copy command). Sorry for wasting your time on this.
Paul
