Post creation Manipulation of a pipe
I have a pipe created that I would like to make scale changes to at a point midway between the ends. What is a simple way to add some control to the object at a desired point.
Hi James - make your pipe from a Sweep1 of some circles around a curve - with History on. Then scale the circles as needed.
Kewl!
On that same model, I was wondering if you’ve a good solution for this:
I’m too far along to match surface my way out of it.
Pipe manipulation.3dm.zip (884.7 KB)
