Possible to change stroke align direction? similar to what you can do in illustrator
I looked around the forum and haven’t seen this question but was curious if we can change the stroke direction, I believe by default it is set down the center of curves. Would be cool to have a stroke option that you could apply to closed curves similar to illustrator - center, inside and outside. being able to Export .eps files would be nice as well.
Hi - there is no such thing as stroke direction in Rhino. Could you provide some more information on what it is that you are trying to do?
I think he’s thinking of PrintDisplay…
@Ryan656 the thickness you see is not really the same thing as a stroke in Illustrator, it’s just the line weight when printed on paper. Classically CAD programs use these differently than illustration programs.
