Possible glitch in Orient on Srf
One of my students just ran into a possible issue. Rhino 8 in Windows. On first use, Orient on Srf has both Uniform params and Angle params available. But when the command is executed a second time on the same object, those params are greyed out. I was able to duplicate. Discovered that when the project is saved and then reopened, Orient on Srf is fully functional again. But again on second use not all functions available.
Hi Gary - thanks, I see this.
RH-80091 OrientOnSrf: settings grayed out
