Possible conflict between Rhinoceros and Corsair iCUE software
Dear Sirs,
I’ve encountered a strange behavior on my workstation related to Corsair iCUE.
I have eight Corsair iCUE Link fans installed and controlled via the iCUE software. On my Stream Deck, I’ve configured several buttons that trigger different fan speed profiles and LED color schemes based on case temperatures.
However, whenever I create new materials in Rhinoceros or switch between different OpenGL display modes, the fan LED animations freeze, and the fans stop responding to any Stream Deck commands.
This issue doesn’t occur with other applications such as 3ds Max or D5 Render, so it seems Rhinoceros might be using some Microsoft libraries also used by iCUE, causing a conflict.
I’ll record a short video to better demonstrate the problem.
Regards.
Out of curiosity: does it happen with Blender when using Cycles?
I don’t use Blender but I can check it.
