Hi @Mike24
I’ll try t break this down to help you wrap you head around this:
l = rs.AddLine((0,0,0), (0, 100, 0))
# l is now an object-id representing a rhino object
objl = rs.coerceline(l)
# objl is a copy of the geometry of l ( a Rhino line)
# there is no reference back to the rhino object l
print objl.To # clear: print the To point
# here you rotate the rhino object l, but this does not affect objl in any way
rs.RotateObject(l, objl.From, -90, copy=False)
print objl.To # clear: print the same To point
# What you would do to get the expected result is:
objl_2 = rs.coerceline(l)
print objl_2.To
Does this make sense?
With your background in programming I think you will benefit a lot from checking out the rhinoscriptsyntax module.
eg rs.RotateObject():
def RotateObject(object_id, center_point, rotation_angle, axis=None, copy=False):
"""Rotates a single object
Parameters:
object_id (guid): The identifier of an object to rotate
center_point (point): the center of rotation
rotation_angle (number): in degrees
axis (plane, optional): axis of rotation, If omitted, the Z axis of the active
construction plane is used as the rotation axis
copy (bool, optional): copy the object
Returns:
guid: Identifier of the rotated object if successful
None: on error
Example:
obj = rs.GetObject("Select object to rotate")
if obj:
point = rs.GetPoint("Center point of rotation")
if point: rs.RotateObject(obj, point, 45.0, None, copy=True)
See Also:
RotateObjects
rc = RotateObjects(object_id, center_point, rotation_angle, axis, copy)
if rc: return rc[0]
return scriptcontext.errorhandler()
RotateObjects():
def RotateObjects( object_ids, center_point, rotation_angle, axis=None, copy=False):
"""Rotates multiple objects
Parameters:
object_ids ([guid, ...]): Identifiers of objects to rotate
Returns:
list(guid, ...): identifiers of the rotated objects if successful
Example:
objs = rs.GetObjects("Select objects to rotate")
if objs:
if point:
rs.RotateObjects( objs, point, 45.0, None, True )
See Also:
RotateObject
center_point = rhutil.coerce3dpoint(center_point, True)
if not axis:
axis = scriptcontext.doc.Views.ActiveView.ActiveViewport.ConstructionPlane().Normal
axis = rhutil.coerce3dvector(axis, True)
rotation_angle = Rhino.RhinoMath.ToRadians(rotation_angle)
xf = Rhino.Geometry.Transform.Rotation(rotation_angle, axis, center_point)
rc = TransformObjects(object_ids, xf, copy)
return rc
TransformObjects():
def TransformObjects(object_ids, matrix, copy=False):
"""Moves, scales, or rotates a list of objects given a 4x4 transformation
matrix. The matrix acts on the left.
Parameters:
object_ids [(guid, ...}): List of object identifiers.
matrix (transform): The transformation matrix (4x4 array of numbers).
copy (bool, optional): Copy the objects
Returns:
list(guid, ...): ids identifying the newly transformed objects
Example:
# Translate (move) objects by (10,10,0)
xform = rs.XformTranslation([10,10,0])
objs = rs.GetObjects("Select objects to translate")
if objs: rs.TransformObjects(objs, xform)
See Also:
TransformObject
xform = rhutil.coercexform(matrix, True)
id = rhutil.coerceguid(object_ids, False)
if id: object_ids = [id]
elif isinstance(object_ids, Rhino.Geometry.GeometryBase): object_ids = [object_ids]
elif type(object_ids) in __allowed_transform_types: object_ids = [object_ids]
rc = []
for object_id in object_ids:
id = System.Guid.Empty
old_id = rhutil.coerceguid(object_id, False)
if old_id:
id = scriptcontext.doc.Objects.Transform(old_id, xform, not copy)
elif isinstance(object_id, Rhino.Geometry.GeometryBase):
if copy: object_id = object_id.Duplicate()
if not object_id.Transform(xform): raise Exception("Cannot apply transform to geometry.")
id = scriptcontext.doc.Objects.Add(object_id)
else:
type_of_id = type(object_id)
if type_of_id in __allowed_transform_types:
if copy: object_id = System.ICloneable.Clone(object_id)
if object_id.Transform(xform) == False: #some of the Transform methods return bools, others have no return
ot = scriptcontext.doc.Objects
fs = [ot.AddPoint,ot.AddLine,ot.AddRectangle,ot.AddCircle,ot.AddEllipse,ot.AddArc,ot.AddPolyline,ot.AddBox,ot.AddSphere]
t_index = __allowed_transform_types.index(type_of_id)
id = fs[t_index](object_id)
else:
raise Exception("The {0} cannot be tranformed. A Guid or geometry types are expected.".format(type_of_id))
if id!=System.Guid.Empty: rc.append(id)
if rc: scriptcontext.doc.Views.Redraw()
return rc
As you can see these are wrapper functions with quite some coercion and input sanitation.
However the core functionality is all Rhino. and the scriptcontext module.
That module ‘taps into’ the current document to read and write all objects, layers, properties etc etc.
Does this all make sense?
HTH
-Willem
