I’m having a curious problem in the WIP, here’s the workflow:
Open file, select mesh, run dupborder command
Rather than seeing 1 closed curve around the border of the mesh, I get 52 open curves, many overlapping.
A separate (maybe related) issue: If I run the showedges command on the mesh, naked edges do not appear in any rendered viewport unless the Zoom command is active.
Thanks as always. EDIT: both functions work perfectly in V5.
ARM TEST v6.3dm (877.7 KB)
