(This issue relates to v5A854. Not sure if it affects v5A858 which I’ve not downloaded due to working off a mobile hotspot while traveling.)
In a drawing with eight layers and three sublayers, I encountered an unusual problem with layers. Unfortunately, I can not replicate it, but thought I’d share the following in case it’s at all useful to keep an eye on.
I renamed the default layer (sort of always wondered—is this a bad thing?) and added three sublayers. With another layer selected (not a sub-layer) I wanted to turn off the (renamed) default layer. However, I was unable to turn it off. After a dozen or so attempts at selecting different layers and trying to turn off the desired layer, I noticed that none of the radio buttons were lit to indicate which layer was selected.
Some more clicking around on the layer select buttons and the radio button finally came back. Then the default layer was able to be turned off.
~Dave
Software information
Software versions
Rhinoceros version: 5.0 (5A854)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
OS X version: Version 10.10.3 (Build 14D136)
Plug-ins
//usr/lib/libmecab.dylib
Third party kernel extensions
com.Logitech.Control Center.HID Driver (3.9.1)
com.Logitech.Unifying.HID Driver (1.3.1)
org.virtualbox.kext.VBoxDrv (4.3.20)
org.virtualbox.kext.VBoxUSB (4.3.20)
org.virtualbox.kext.VBoxNetFlt (4.3.20)
org.virtualbox.kext.VBoxNetAdp (4.3.20)
Hardware information
Computer hardware
Hardware model: MacBookPro8,3
Processor: Intel Core i7-2860QM CPU @ 2.50GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon HD 6770M 1024 MB
Memory: 1024 MB
Screen size: 1920 x 1200
Displays: Color LCD (133dpi 1x)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: Apple Internal Keyboard / Trackpad
Logitech: USB Receiver
Apple Computer, Inc.: IR Receiver
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-1.32.20
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: High
