in this post I describe my problems with running a grasshopper solution using CPython. Rhino.Inside can be used with C# and JS too, so my question is, wether it is currently possible to use these to run a grasshopper solution. It has to work, as Rhino computes uses Rhino.Inside too as far as I know and Rhino.Inside with Revit enables Grasshopper use too.
Thanks for the clarification.
