Positive values creating geometry below C-Plane rather than above
Hi there, I have positive values creating guides and then geometry below the C-Plane rather than above it, and when typing negative values, the geometry appears above. How do I fix this? In what setting? Thanks!
Can you post the file or part of it? I’m wondering if you have a custom Cplane maybe.
Ah - thank you - nevermind though - I think it had something to do with WHEN I was entering in the value and when I moved the mouse into the Front viewport for the positive value - I think I fixed it.
Hi Courtney, you can also enter the letter w in front of your coordinate, eg. w10,10,5 so it gets interpreted identical in every viewport. There is a helpful section in the helpfile under “coordinate entry” for other useful prefixes.
c.
