Position of end cut planes has resulted in a slanted column
Hi, there is a problem with some curves - lines, exported from SAP.
RiR does not allow you to see any of the beams. The error is as follows:1: :heavy_check_mark: Position of end cut planes has resulted in a slanted column without any geometry. {685597} . 5. Transaction RolledBack and aborted. This is not the end of the story because you cannot read it at all. No weary of me being wrong.
Thank you
Hi 9pb,
I changed the post topic to Rhino.inside - Revit.
We will need more information to be able to help.
Hello, Japhy.
Now you can translate some curves that are sold from SAP to Revit. You want the file with the curves, the error me lo da with the vigas “Beams”
INTRODUCIR EN REVIT_ PREFERENTE_ VIGAS Y PILARES_ 04-06-2024.gh (22.7 KB)
Sorry:
Hi, Japhy.
I have to transfer some curves that come from SAP to Revit. I send you the file with the curves, the error is with the “Beams” beams
Please include your About info, we support multiple version of Revit and Rhino.
Sorry. Revit 2024.2
Your curves look ok here, no major errors.
Rhino.Inside Revit: 1.23.8919.31374 (2024-06-02T17:25:48)
Rhino: 8.9.24156.10001 (Rhino 8)
Thank you!
