I’d see how Parallel.ForEach fares. It’s for sure the easiest if you are OK with hiding the threading entirely.
It isn’t going to make a difference it the main thread is locked up waiting for all of the other threads to complete. We use the ‘get with timeout’ approach in things like Make2d
I’m not having much luck with multithreading, so I’m thinking I could take another approach, which might actually be better for what I’m trying to do:
have an external program that launches instances of rhino and automatically calls a command to start a simulation, then when finished exits rhino.
How might I do this? Are there any .net projects already set up to do something like this?
Thanks,
Sam
External access is done through a process called automation.
Thanks Steve, I’ve got that working (code I copied below), though some issues/questions.
- I see Rhino come up under background processes in task manager, but it doesn’t disappear after exit is called. How can I make sure Rhino closes?
- Sometimes the geometry isn’t created. I think this is happening when I don’t end task on the rhino in background processes before opening a new instance. I’m hoping I can run multiple rhino instances, so any thoughts on how to get around this?
- Is there a way you recommend to send information back to the automation program? I’m thinking I might just generate a text file and then continuously check it…
Thanks,
Sam
' Create Application or Interface object
On Error Resume Next
Dim objRhino = CreateObject("Rhino5x64.Interface")
'Dim objRhino = CreateObject("Rhino5.Application")
If (Err.Number <> 0) Then
MsgBox("Failed to create Rhino5 object")
Exit Sub
End If
' Make attempts to get RhinoScript.
' Sleep between each attempt.
Dim nCount As Integer
nCount = 0
Dim objRhinoScript As Object
Do While (nCount < 10)
objRhinoScript = objRhino.GetScriptObject()
If Err.Number <> 0 Then
Err.Clear()
Sleep(500)
nCount = nCount + 1
MsgBox(nCount)
Else
Exit Do
End If
Loop
If (objRhinoScript Is Nothing) Then
MsgBox("Failed to get RhinoScript")
End If
Call objRhino.RunScript("_Circle 0 10", 0)
Call objRhino.RunScript("_Line -5,-5,0 5,5,0", 0)
Call objRhino.RunScript("_Line 5,-5,0 -5,5,0", 0)
Call objRhinoScript.Echo("Geometry created.")
Call objRhino.RunScript("_-Save C:\Users\Sam.lochner\Desktop\test.3dm _enter ", 0)
Call objRhinoScript.Echo("File saved.")
Call objRhino.RunScript("_Exit ", 0)
Call objRhinoScript.Echo("Done!")
