Poodle Morph Pro: CATIA-Level Die Morphing
Experience PMX (Poodle Morph Transformation), the new standard in die morphing.
Poodle Morph Pro, a high-precision surface morphing solution for automotive press die engineers, is now officially available on Food4Rhino.
Technical Features
  • Resolves Core Engineering Needs: Perfectly addresses morphing, the most demanding and critical task for automotive press die modeling in Rhino.
  • True High-End Alternative: Achieves G2 continuity and precise springback compensation. This single morphing tool completely replaces the need for expensive high-end software (CATIA, UG NX, VISI, etc.) within Rhino.
  • Dedicated Curve Generation Tool: Equipped with a specialized curve generation feature optimized for morphing, drastically reducing time spent on complex pre-processing.
  • Stable Cloud Computing & Security: Processes heavy data seamlessly and stably through a dedicated server environment built with strict security protocols.
Operating Policy
  • Pay-as-you-go System: Operated strictly on a pay-as-you-go basis. There are no initial software purchase costs; users pay only for the exact number of uses.
Download & Links
