Polysurfaces Occlude Curves in VaPlanViews The display mode below for the VaPlanView (on the left) is Wireframe, so it should be more transparent than ever.
Also 2) The lines above the platform (selected) aren’t rendered in the VaPLanView. It turns out, on exploration, that the VaPlanView won’t show lines above a Levels’ Cut Plane, even if it isn’t active in the view.
I don’t see the advantage to either of these behaviours.
It’s the same whether they have a draw order or not. I have to put lines on the viewing side of polysurfaces for the lines to show, even if working in Wireframe.
We haven’t received any file from you. You mentioned you used the McNeel file upload. We didn’t get any email with the link. Can you send it using a different method like WeTransfer?
