Polysurface parameterization, Splop?
Hi everyone, I need to recreate this pattern
7731a5649ac928c46455b85d56a5d9e4
I tried with creating parametric curves and then applying a loft on them but it did serve my intention.
Then I discovered the Splop command but I’m having some problems in appying it.
What I wanted was to create some spheres on which the surface would wrap onto (another guess was to use a pipe instead of spheres), but clearly it doesn’t work like this.
Is Splop the right command to use? Is there any way to parametrize a surface like this?
Here’s my guess at it, It tried different times with no results. I hope some of you can help me.
Thanks in advance
Splop on spheres.gh (16.2 KB)
My guess is that this is based on attractors and not wrapping.
Original work from Ora Ito for Reebook
He link that could be interesting
That’s really helpful. Thank you so much, really appriciated!
