Polysurface Intersection at Surface with BooleanDifference?
Result I’m looking for (right image): I want to cut each polysurface at the LOWEST (nearest to cplane) intersection with the surface, with a plane parallel to the CPLANE.
What I think I need: a way to find the LOWEST intersecting 3d point / then a bounding box the size of the surface moved vertically to that point / then a BooleanDifference of the polysurface and the bounding box.
I need to do this with dozens of polysurfaces in bundles across dozens of surfaces
Sounds like you need a script? Or a grasshopper method. Are you going to post your file with this or multiple instances? :slight_smile:
I am not familiar working with scripts, but I can work with grasshopper a little bit.
I wanted to post the question before the design was completed, so I can work towards the solution!
If you need the design to better help me, I will post it once it is ready.
Thanks
You may achieve it with Sort List and for your reference.
About Sort List Grasshopper Online Document
SortList.gh (14.6 KB)
:+1:
Yes, that, and a screenshot of the ‘ideal’ result you’d achieve manually with one set.
