Which file are you trying to open? It must be a mistake in one of our example models where we use the PolylineOffset component of this small “Curve Offset Tools” plugin we developed and use mostly internally.
If you tell me which of our example models uses this plugin I will update it to remove this dependency. In the meantime, you can also just install it separately, I am attaching it below. It will probably be included in the ShapeDiver plugin in the future.
Since I didn’t make the file I’m trying to open, I don’t know.
There is a possibility that the person who made this, is using an older version of the software?
Thanks for the installation file, It fixed the pop-up!
“How To Generate Complex Technical Drawings w/ Grasshopper | Pt. 1”
I opened the provided file in Grasshopper and some components were not recognized due to missing plug-ins.
These plugins are new to me: pufferfish, shapediver, heteroptera and human. After installing the missing plugins there was still a single component that grasshopper couldn’t recognize. It was exactly this CurveOffset component. I used the download you provided and now all components are recognized for me
