Polyline fails when layout tab is open
(Bug)?
Hi, when I have a layout window open in rhino for mac the Polyline command fails, the only way to draw a line without the command failing is to draw one line at a time?
Is this a bug?
Hi Dylan, What version of Rhino are you running? Please run SystemInfo in the Rhino command line and paste the results.
I tested like this in Rhino 8:
  1. create a new layout
  2. create a polyline in the layout.
  3. created another polyline for good measure.
Hi Japhy,
I’ll paste the results, just to note I am still drawing in the model space. Its there where I am having the issue.
I also have
Rhino.AdvancedSettings.IncludeLayoutsInDocumentWindowDeprecated
Set to false so that I can pop out my layout screen and see how my drawing will look as Im drawing, I also have my PrintDisplay on so that I can view the line weights.
I will say this workflow is extremely buggy and makes it difficult to draft in 2D.
Here is the results of the SystemInfo:
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15432, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Evaluation, build 2024-05-17
License details: Cloud Zoo
Expires on: 4700831-10-20
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 8GB)
Mac Model Identifier: Mac14,2
Language: en-IE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
  Apple M2
    Color LCD (1470 x 956 @ 60.00Hz)
USB devices
  None
Bluetooth devices
  None
Third party kernel extensions
  None
Third party plugins
  /usr/lib/usd/libusd_ms.dylib
  /usr/lib/swift/libswiftCoreML.dylib
  /usr/lib/swift/libswiftFileProvider.dylib
  /usr/lib/swift/libswiftGLKit.dylib
  /usr/lib/swift/libswiftGameplayKit.dylib
  /usr/lib/swift/libswiftMetalKit.dylib
  /usr/lib/swift/libswiftModelIO.dylib
  /usr/lib/swift/libswiftSceneKit.dylib
  /usr/lib/swift/libswiftSpriteKit.dylib
  /usr/lib/swift/libswiftVision.dylib
  /usr/lib/swift/libswiftShazamKit.dylib
  /usr/lib/swift/libswiftObservation.dylib
  /usr/lib/swift/libswiftVideoToolbox.dylib
  /usr/lib/swift/libswiftWebKit.dylib
  /usr/lib/swift/libswiftNaturalLanguage.dylib
  /usr/lib/swift/libswiftMapKit.dylib
  /Users/dylan/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/Enscape.Rhino8.Plugin.rhp	"Enscape.Rhino8.Plugin"	0.0.24103.837
  /Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.7.24138.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.7.24138.15432
  /Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.7.24138.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.7.24138.15432
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	8.7.24138.15432
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.7.24138.15432
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.7.24138.15432
  /Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	8.7.24138.1002
  /Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp	"Legacy Rhino Render"	8.7.24138.1002
  /Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.7.24138.1002
  /Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.7.24138.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.7.24138.15432
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.7.24138.15432
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.7.24138.15432
Thanks for reporting RH-82054 I was able to repeat it. If i close the polyline by clicking the endpoint its fine, if close via the command line or persistant close it fails. Close the floating layout and it works as expected.
