Not sure why this is happening but one polyline (of expected 38) is not created with the region union component. How do I fix this?
Unexpected Empty Path - Region Union.gh (24.3 KB)
TIA
H
TIA
H
@martinsiegrist not an issue with Pufferfish…
Unexpected Empty Path - Region Union (Not Pufferfish).gh (24.2 KB)
TIA
H
Yes but your definition requires Pufferfish and if someone is trying to help you but doesn’t use Pufferfish or Lunchbox, it’s a waste of time to download the definition.
If the issue is not related to Pufferfish or Lunchbox, you can upload a definition which does not use any plugins and the topic tags can be removed.
@martinsiegrist I’ve removed Pufferfish. Not sure how to replace the Lunchbox one.
Unexpected Empty Path - Region Union (Not Pufferfish2).gh (23.5 KB)
TIA
H
You can plug the output of the Lunchbox components into a Brep or Curve component and internalize the data.
Okay. Hope you can open it now.
Unexpected Empty Path - Region Union (No Pufferfish, Lunchbox).gh (43.3 KB)
TIA
H
@martinsiegrist Apologies. Missed the reparameterize curve component. Here’s the updated. Let me know if you still can’t open it.
Unexpected Empty Path - Region Union (No Pufferfish, Lunchbox2).gh (48.7 KB)
TIA
H
scaling your model by 1000 seems to solve the issue:
you might be using very tiny geometries, probably with a Rhino tolerance which is not low enough
[edit]
for what is worth, even scaling just by 10 gives the expected results:
Great. Thanks Inno!!!
The attached file works fine if the tolerance is set to 0.0001
Unexpected Empty Path - Region Union.gh (62.5 KB)
Yep. Just changed it.
