Is there a way to set the polyline to default to persistent close=no?
Thanks,
Dennis
Thanks,
Dennis
Hi Dennis - On my system, in between Rhino sessions, the default is restored to PersistentClose=No
. When you change that during a session, this change is remembered for the duration of that session. Are you seeing something else?
Exactly the opposite. But sometimes after I change it to NO it resets to YES.
Hi - I haven’t seen that here. Could you give a specific and detailed description of the workflow that leads to this behavior?
Hello - you should be able to trick Rhino by adding a macro to your startup commands in Options > General page:
_Polyline _PersistentClose=_Yes _Enter
Will do Pascal. Thanks.
Dennis
